TwinTurbo.NET: Nissan 300ZX forum - NO CAPS PLEASE. It doesn't warrant help.
Subject NO CAPS PLEASE. It doesn't warrant help.
Posted by CoHPhasor on August 01, 2010 at 9:07 PM
  This message has been viewed 98 times.
In Reply To HELP posted by LEVARIOXL on August 01, 2010 at 08:13 PM
There are plenty of connections that could be funked out after 2 yrs.
Check the majors and work your way down.
CAS, PTU, Coils, Injectors, Battery, etc.
Green/White is bad.
2 yrs? I don't know what tells you the fuel pump is fine, but that Fuel Filter needs a once-over.
We also don't know much about what you've done.
Honestly? You told us you had no boost so you replaced the turbos,.... at this point you may have replaced them for no reason because you didn't know any better.
Give us something to work with ;-)
